Hosted by Frederick Boucher
Railroad Dioramas
Posted: Thursday, November 03, 2011 - 10:37 AM UTC
Posted: Thursday, November 03, 2011 - 10:54 AM UTC
Posted: Friday, November 04, 2011 - 04:22 AM UTC
Posted: Monday, November 07, 2011 - 11:21 AM UTC
Posted: Monday, November 07, 2011 - 11:56 AM UTC
Posted: Tuesday, November 08, 2011 - 11:45 PM UTC
You know I think that this would make a great model either as a entertainment park scene or a dummy locomotive.Model trains pass many structures on their journeys ,a movie set is just one of those structures that can be depicted in scale.
I have heard that this kit is subject to warping.This is probably true if left out in the sun on hot tracks,sand,pavement etc....I have tested the plastic myself and it is no more subject to this problem than any other plastic that I have worked with.And yes there are options,one of those being to support the structure before assembly.I think that I would try coating the interior of the larger pieces with exopy,fiberglass or some other warp resistant material.Where the plastic touches hot metal like tracks make a section of the wheels in wood which is a great insulator.
For indoor setting I don't see a problem at all unless you were to put it next to a wood stove or other high heat generating source.When I do my 2nd General I will experiment with this a little further.
As far as availability is concerned just do some networking.I am sure that there are lots of Generals sitting in closets waiting to be built.I got the one that I am working on now for the price of the postage.It was partially started (a small bit of the tender) but no harm was done and the parts were still all there.I have also seen many sell on ebay for less than 50 bucks,new and in the plastic packages.
Personally if I was to do a G scale layout I would do it with a movie making theme of which the General would be just one of the structures that I pass along the way.I would do it as a "out of season" amusement park thus avoiding anything that would move other than the train .Having to make or modify all those figures would also be quite unnecessary.
Sounds like fun doesn't it ?
Once Upon a time.........dioramas by JohnReid
Posted: Sunday, November 13, 2011 - 12:26 PM UTC
Posted: Monday, November 21, 2011 - 05:36 AM UTC
nother pic
Posted: Tuesday, November 22, 2011 - 12:38 AM UTC
Posted: Tuesday, November 22, 2011 - 01:51 AM UTC
Morton's Car
The choice I have here is between a straight passenger car or a combo.
The first choice would be to pretty much scratchbuild the whole thing beginning with the shell.The lower combo car has some of the work already done for me.Having already built a wood version I think it may be fun to do the plastic version and make it look like wood.
Luckily for me the plastic itself is colored and not just painted which will make my job a lot easier.It is also more interesting as it is already broken down into two sections passengers and baggage. The baggage side could be set up for movie making purposes while the passenger side could contain a portion of Morton's car as seen in the movie.
This is an abandoned movie set so a lot of stuff would have been removed and the set will be depicted as having fallen into some disrepair.
The steps at the far right I can use for Jill's arrival scene and the view through the windows will be of Monument Valley.
Posted: Tuesday, November 22, 2011 - 06:40 AM UTC
Posted: Wednesday, November 23, 2011 - 01:31 AM UTC
This is all way too crowded together but it gives you guys an idea about how the final composition will look.
Posted: Thursday, November 24, 2011 - 12:21 AM UTC
After gutting the car,removing the seats and wiring,I laid a sub-floor in basswood on the passenger side of the car.I haven't yet decided whether to leave the sky lights as is of remove them and put up clear glass.The detail on the glass looks a little overscale to me.
I strengthened up the roof line a bit by adding 1/4 x 1/4 lumber in anticipation of cutting out the cars side.This is necessary to keep the cars structural integrity while working on it.The hole in the side is for movie making purposes.
Posted: Thursday, November 24, 2011 - 11:46 PM UTC
The next step will be to lay the finished floor in Morton's car.Hardwood floors on his side while the rest will be pine.I try to hand select each board for color and contrast.Using a darker one right up next to a light one will help to achieve what I am looking for.
Posted: Saturday, November 26, 2011 - 12:24 AM UTC
Even though it is separated into two compartments there still is lots of space to work with.The baggage side will eventually become a storage area for old props etc..
I have removed the orange windows even though they made for a nice warm glow inside as they were overscale plus I like to have complete control of the lighting including color.The ceiling has been finished with cherry wood veneer and I am now boxing in the beams in walnut veneer.
In Mortons car there was a lot of brass tubing hanging from the ceiling above to be used as handrails to steady himself as he moved about his private car.He was disabled and slowly dying from bone disease.
Posted: Saturday, November 26, 2011 - 10:32 AM UTC
I have decided to have a bit of fun laying the floor in Morton's compartment.I have gone one size larger on the planks(stir stiks)which gives me a nice edge to work with when doing the following technique.Wood floors can be quite beautiful when laid properly.I want to try a technique that I haven't used since my old ship building days of HMS Victory.Morton must have hired a couple of unemployed shipbuilders to do the floors and cabinetry for his rail car.There will be no visible nails or wood trunnels holding the floor in place.There will however be a black waterproof caulking material between each board which will make the floor more interesting to the eye.The wood is birch.
Posted: Thursday, December 01, 2011 - 09:01 AM UTC
Posted: Friday, December 02, 2011 - 12:21 AM UTC
Ya know when aging and weathering hardwoods I found found that the best way to do it is too weather it as it would do naturally,in other words from a polished finish to a dull.In this way you can retain the beauty of the grain as it seemingly ages.The birch floor for example was originally a gloss finish that was dulled using very fine sandpaper for the wear and tear, then chalk pastels representing the build up of crud over the years ,followed by a spray of matte acrylic fixative to hold it all in place.Later more crud can be built up in all the cracks and crevasses
and to create shadows.
Posted: Friday, December 02, 2011 - 01:18 AM UTC
Posted: Sunday, December 04, 2011 - 07:43 PM UTC
Old weather beaten ceiling from inside with a wood frame underneath and another layer of boards on top to create the roof.
Posted: Sunday, December 04, 2011 - 08:12 PM UTC
Here is a little example that I did on the movie making side of the old station car.There just is no comparison between the plastic and real wood and it really isn't hard to do on the outside of the car.Morton's car will be dark green however.
Posted: Tuesday, December 06, 2011 - 06:06 PM UTC
Please note:
I have moved all the pictures in my photobucket taken up until now ,from the General Album to the G Scale Trains Album.Moving pics will cause them to delete in the General thread but they are still available on my G scale album for those who may be interested.
Bending stripwood:
Bending wood is simple for a rectangular roof such as this,shipbuilding is another story.I just use plain old warm tap water and soak the area that I want to bend for a few minutes in this case.(The thicker the wood ,the longer the soak) .I then take an old stick type hair curler and put it in a holding devise,I use a clamp. I then let it warm up to hair curling temperature which seems to be just perfect for bending thin strip wood like this.I hold the dry end in one hand and with the other wet end I use a pencil with an eraser on the end and apply increasing amounts of pressure with the eraser until I get what I am looking for.
Why the eraser end ,well it helps as a tool for bending instead of your fingers and tends not to slip on the wet surface.Keep checking that you are getting the proper bend and re-soak and do it again if necessary.You will want to slightly over bend it as there is a certain amount of spring back when the pressure is remove.If the piece of wood you are working with keeps breaking turn it over and try to bend it the other way.Use only straight grained wood running lengthwise on the strip as cross grain simply won't work without breaking.Most hobby woods bend without any problems.I used the thin long type coffee stir stiks used to stir the extra large double doubles.Your local coffee shop manager may sell you a box for a few bucks especially when you tell him what your using them for.He probably built models too in his younger days !
Most stiks and tongue depressors are birch wood ,which is in the hardwood category. So depending on the thickness they will require more soaking time in hotter water than say basswood , popular or pine.Have fun and good luck !
The above is in answer to a question I got from a another modeler.
Bending stripwood:
Posted: Saturday, September 15, 2012 - 10:01 PM UTC
Well the workbench is clear so now it is back to the Sergio diorama.I plan to do this one modular style too beginning with the central theme of a movie set and then if I decide to I can add from there.Right now there are three main components the locomotive(as a prop) the station from the opening scene and Morton's car.
The first thing to do is make up a track bed for Morton's car.I only have round track so at present I am straightening a couple of sections out by modifying them.
Posted: Saturday, September 15, 2012 - 10:17 PM UTC
Posted: Sunday, September 16, 2012 - 01:27 AM UTC
The first thing to do is modify a bit of track from round to straight.
