Hi Guys,
After a disaster of a first attempt at painting flesh tones after a long period of quite serious illness.
I discovered a brilliant way to strip acrylic paint off, using badger airbrush cleaner and an electric toothbrush ( a discarded head)i was able to completely remove several coats of paint
method
spray cleaner on surface then work the brush over it,
you'll get a very sticky surface then using some soap,or shower gel clean this off using the electric toothbrush then just repeat until the surface is clean, it took several minutes but was alot quicker than soaking in nail varnish remover or oven cleaner and the electric toothbrush was able to get into all those nooks and crannies.
anyway try it see how it works for you as you can pick up basic battery toothbrushes in pound shops these days its worth a go
Simon
paint removal
montythefirst
KitMaker: 1,055 posts
Historicus Forma: 601 posts
Posted: Tuesday, June 05, 2012 - 02:35 AM UTC
Maki
Posted: Tuesday, June 05, 2012 - 05:47 AM UTC
Good to hear you are doing better Simon.
As for paint removal, I always used oven cleaner with great results. Recently one of my friends suggested Revell aqua cleaner and I loved it... very easy to apply and thick paint layers were off in a matter of seconds.
montythefirst
Posted: Tuesday, June 05, 2012 - 08:30 PM UTC
Thanks Mario
never used that but will look out for it
Simon
