Ford Style Farm Tractor .
So how does this metal model come together? Let’s take a look!
I did not photograph every step leading up to assembly although I will describe it. White metal kits are handled much like a resin model. The first thing one should do with a white metal kit is scrutinize it for any flash, seam lines, holes, etc. Compared to resin parts, metal tends to be malleable and less brittle. It also does not sand as well, although one can sand metal. I spent an hour cleaning up some minor flash and seams while watching TV. I also filed several surfaces to make the parts mate smoothly.
Next, prepare the metal for glue and paint. Do this by first scrubbing them with soap and water. Next is an important step, bathing the parts in vinegar for a few hours. Vinegar is a mild acid. It imperceptibly pits the surface, and it further cleans the metal.
To start off easy I joined the main wheel haves together. Aligning the spokes takes a bit of rotating one side to find the right combination. I finally did and secured them with CA. They look good and I do not see anything that needs filing. There is, however, a secret to these assemblies which I will not share until the end of this build!
WMS tells us that this model is made up of several min-models. First, I assembled the combination engine, transmission, and rear axles.
Then I assembled the radiator and fuel tank. These subassemblies are a challenge! The tank halves have no tabs or pins; the top and bottom pieces are slippery upon each other and alignment is eyeball only! When I build another, I will glue small plastic tabs inside of one half, much like one does when building a vacuform model, or many other cottage industry kits. Finish it by attaching the dash panel. Be careful aligning it as the panel’s angle against the tank is very important when the assembly is mated to the radiator, and thence to the transmission and differential part. After the initial CA set, I flooded the inside of the tank with gap filling CA to both fill gaps, and reinforce the seams between the three parts.
The radiator subassembly seems simple: insert the fan baffle into one side of the radiator, then attach the cross brace underneath. The cross brace was fashioned for the railway tractor and sports a pair of end brackets which need to be removed. It also has two faint pins to mate into shallow dimples under the radiator. I drilled those out as there is not much room for the pins. The cross brace also has a semicircular fairing that is intended to be removed. The fairing will conflict with joining the special axle brace made to build this model as a traction tractor. When affixing the axle to the cross brace, again alignment is very important. All of these parts were joined with CA. The fit was good although pins and dimples, or other means to help align the parts, are necessary.
Now attach the tank and the radiator. This is difficult. Only a narrow shelf at the end of the tank fits onto a lip around the radiator. There really isn't a way to clamp these parts together except by good ol' shaky fingers!
If you do not accurately align the top and bottom halves of the tank, the joint between the tank and radiator will be askew. The tank spaces the dash panel and the radiator for spanning the engine. While the bottom of the dash panel is contoured to seat onto the tranny case, the radiator assembly attaches to the nose of the engine via a small cupped tab which attaches under a small lip on the front of the engine. Clearances are extremely tight. I broke the tank away from the radiator several times. I scrapped the mating surfaces to create something for the CA to hold to; if it breaks again, I will reinforce it with epoxy or gel CA.
What you see above is approximately 3.5 hours of work, including the hour spent cleaning the pieces.
More photos will be posted soon! Thanks for reading and check back soon!
