He’s listed as 1/35 and comes to chest height on a normal 1/35 figure. He’s cast in resin with the body from neck down as one piece. The head is separate. The base has a small log behind the position for the figure. There are three resin mushrooms which can be placed anywhere. He is carrying a shillelagh but the back part of the handle was lost so I replaced it with plastic rod. In presenting him, I wanted a pot of gold. Lacking a pot, I found an old Historex pitcher and cut it down and drilled it out. The gold coins were cut from a 1mm plastic rod and dropped into the pot. Thanks to our friend, Mr. Static Electricity, this was harder than expected. The coins were fixed into the pot with a small drop of AK Interactive pigment fixer. The ground work is Silfor tufts over Celluclay. The base is from Birch Tree Enterprises. He is painted in Vallejo Acrylics.
I got him from Sentinel Miniatures at Baycon just over a week ago.
