Sculpting
Discuss sculpting techniques, tricks, and share your original works.
Orc "Bandolero"
Rauko_Din
Sevilla, Spain / España
KitMaker: 67 posts
Historicus Forma: 47 posts
Posted: Thursday, August 21, 2014 - 05:23 AM UTC
Hello all
I want to show you my bust of an Orc Bandit "Bandolero".
The orcs Bandoleros were very famous in XIX century in southern Spain because they not only ransacked the rich but they ate them after.
Well I hope you like, here you are the process:
Rauko_Din
KitMaker: 67 posts
Posted: Thursday, August 21, 2014 - 05:36 AM UTC
The other day I finally dusted off the silicone and the resin and began to make several copies to my little tough guy. I also wanted to try a way to make bases that I thought walking along the Cádiz beach, seeing rock fragments detached from the concrete blocks that there are for protection of shore. Many of these stones have several flat sides and I thought it might be a pretty original pedestals for busts. After, each time I've ever encountered a boulder with proper form, has finished in my pocket, increasing my reputation of mad between family and friends.
I did the mould quite flexible and one piece to avoid joints, the problem is that deforms when you put the resin inside. The upside is you can play with it while it hardens ,you can get different shapes with the same bust, fatter or slimmer orc depending if you push the mold or limit the deformation.
The pedestal has no mystery, you need a proper stone and with a drill for stone, water and patience will make a slit. Then I used brass tubing to link the figure to stone. Well, nice and cheap.
Rauko_Din
KitMaker: 67 posts
Posted: Wednesday, February 04, 2015 - 10:22 PM UTC
I've started at last to paint this old friend of mine. Hope you like.
Posted: Thursday, February 05, 2015 - 04:43 PM UTC
Excellent work Fernando.
Rauko_Din
KitMaker: 67 posts
Posted: Friday, February 06, 2015 - 11:31 PM UTC
Thnak You Jesper
