Really good result Fernando, you well managed the green-stuff...I hate green stuff, it always glues on my hand instead on the fig i'm working on !!! Do you have any secret to work with it ?
Secret! Donīt know to say. Itīs true that green stuff is too much sticky, specially if you work with metal tools and itīs quite enervating.
Um!! There is two or three things you can try:
a- First is to mix green stuff with other epoxi putty, like Magic Sculpt or Milliput, variating proportions of both putties you can get differents putties with different textures.
b- Second is use rubber brushes for modelling, are wonderful tools to sculpt in my opinion.
It is much more difficult than the green stuff sticking to them. You can push and make pression to stick it on the figure without fear(or less fear) to it remains stuck to the tool.
I found my first rubber brushes in France precisely. "Je dois aller en France pour travailler de temps en temps". Also are useful to smooth the surface at the same time you sculpt.
c- If you use metal tools like these...
you need to moisten the points with water, neither much nor little (itīs a question of practice) to avoid the adherence and after with little and rapid touches start to stick the green stuff to the rest of the figure, all around the portion, or at least enough, you want to add. When you are sure that it is firm over the surface you can sculpt on it...more or less...thatīs not a exact science
I hope this can help you, if not, don't hesitate to comment.
A bientôt et bon courage.
Fer
