http://imgur.com/a/JIgNt
This is my first time working with O scale trains. The kit I'm starting with is by M.T.H. Electric Trains. In their Premier series, Bay Wndow Caboose, kit No. 20-91436.
This is what I'm going for as the final result.
http://rrpicturearchives.net/showPicture.aspx?id=1564106
If you click on it then you'll see it's almost there already, sort of . . .
I started right away with disassembly and removal of parts that won't be used; roof walk way and ladders. ..
...And cut away the roof ends. Both end walls were also carefully cut and removed for relocation later.
During progress of this project, I'll need to dry fit and take apart this model many times for my style of eye-ball-building-accuracy. I glued in plastic strips to set the correct depth and position of the bed part.
Those CC sent in junk-mail ads were sliced up for this strip material.
They were glued in place with CA through the opening for the bay windows while I was holding it together with my hand.
After that was done, I can now carefully cut the bosses off for relocation later. They are marked and ID'd for correct positioning
Photo album for this build, at least until I get this properly sorted:Photo album for this build, at least until I get this properly sorted:
thanks for looking ….
