i work with oils usually but i think with acrylics you use the same colors just with different tecnique
Acrylic base, depending on what kind of leather it is, dark, clear, reddish, etc .... I choose a medium/dark shade.
Then with oils i prepare a palette on a plate in this sequence:
Cassel earth
Burnt Umber
Raw Siena
Napoli Bright yellow
white Titanium
i mix the colors in the same sequence
Personaly i use oils from Talens Rembrandt but the colors name are standard even if sometime the shade is little bit different between manufacturer
