Sculpting
Discuss sculpting techniques, tricks, and share your original works.
Hosted by Markus Eckmann
How to sculpt moustache and hair 1:35
Anmoga
Spain / España
KitMaker: 456 posts
Posted: Sunday, September 10, 2017 - 09:00 PM UTC
Hi guys,
I am new at sculpting and would like to know how do you sculpt a moustache and head hair at 1:35th scale?
Up til now I have fixed a nose of a resin head which didn't come out because of an air buble and came out pretty well (at least I am happy with the end result).
Thanks in advance,
Angel
Posted: Monday, September 11, 2017 - 04:30 AM UTC
I've used a hot knife (pyrogravure). This only works on plastic heads as the heat will not cut through a resin head. You will also need a heat control, because at full heat the knife will melt right through the plastic.
Anmoga
Spain / España
KitMaker: 456 posts
Posted: Monday, September 11, 2017 - 12:35 PM UTC
Thanks Biggles2.
I want to sculpt the moustache and the hair on a hornet resin head so the pyrogravure is not an option.
I have different putties such as Milliput and Magic Sculpt.
Regards,
Angel
justsendit
KitMaker: 3,033 posts
Posted: Monday, September 11, 2017 - 08:42 PM UTC
Angel, Those putties should work just fine. You might want to take a look at Jerry Rutmann's hair sculpting/addition techniques for inspiration. Here are some examples of his work:
'Another 105mm'
'Kampfgruppe Krause at the Falaise Gate'
BTW: The threads in their entirety are definitely worth a read.
HTH,
—mike
Removed by original poster on 09/12/17 - 15:52:16 (GMT).
Anmoga
Spain / España
KitMaker: 456 posts
Posted: Tuesday, September 12, 2017 - 04:13 PM UTC
Thanks Mike.
I will read them from the beginning to the end.
Regards,
Angel
Neill
KitMaker: 1,255 posts
Historicus Forma: 692 posts
Posted: Friday, September 21, 2018 - 09:33 AM UTC
simplifying use epoxy putty and fine tip sculpting tool.. with metal, a resin or other nonplastic figures.
with Plastic 0 Dragon, Historex, Tamyia, Plastic & pyrogravure
Neill
