Masking Tape Tie-Down Straps
GulfWarrior
KitMaker: 1,051 posts
Posted: Thursday, June 20, 2019 - 06:38 AM UTC
I need to fabricate some tie-down straps for a couple 1/35 fuel cans. I've read that I can do this using masking tape. The problem is, I have NO idea how wide they should be. Anyone have any suggestions?
TIA!
ivanhoe6
Wisconsin, United States
KitMaker: 2,023 posts
Historicus Forma: 54 posts
Posted: Thursday, June 20, 2019 - 06:51 AM UTC
I'd use a gas can with the molded on strap for my measurements.
Sorry, it's not much of an answer but that's how I'd do it.
Hope somebody has a better answer!
GulfWarrior
Posted: Thursday, June 20, 2019 - 06:54 AM UTC
Not a bad idea; but there aren't any straps on the cans; but I know they exist on the real thing.
Thanks for the idea though.
165thspc
#521
KitMaker: 9,454 posts
Posted: Thursday, June 20, 2019 - 07:36 AM UTC
Just measured one of my models. The band on the model worked out to be about 1/25th of an inch. (A little bit wider than 1/32nd by my measure.)
Real tie-downs work out to be slightly narrower than 1 inch wide so a scale tie down should be just under 1/35th of an inch.
GulfWarrior
Posted: Thursday, June 20, 2019 - 07:42 AM UTC
So about .72 mm?
southpier
KitMaker: 546 posts
Posted: Thursday, June 20, 2019 - 08:33 AM UTC
https://olive-drab.com/od_mvg_jerry_can.php
this'll get the pedantic among us started
ivanhoe6
Posted: Thursday, June 20, 2019 - 11:05 PM UTC
I dug out Tamiya's Jeep kit and measured the molded on strap and came up with 1CM for a width or as Michael posted about 1/25th of an inch.
Have a good weekend everybody !
GulfWarrior
Posted: Friday, June 21, 2019 - 02:30 AM UTC
Not to question your measurements; but there are 2.54 cm to the inch so you're saying the strap should be almost half an inch wide in 1/35?
Can someone check my math? Assuming the real thing is 1 inch wide and I want to scale it to 1/35th of an inch which converts to .7 mm. Do my numbers jive?
Santa Cruz de Tenerife, Spain / España
KitMaker: 1,287 posts
Posted: Friday, June 21, 2019 - 11:29 AM UTC
Correct. 0,725mm to be more precise
justsendit
KitMaker: 3,034 posts
Posted: Friday, June 21, 2019 - 11:40 AM UTC
Sounds about right. In this example of a Bronco GPW US fuel can, I sliced Tamiya masking tape to just "shy" of 1/32" (0.0312" – 0.793mm) to accommodate a PE buckle from an 'ABER (35 A113) 1:35 Soviet WWII Infantry Accessories' set. However, I have noticed my straps tend to vary +/- depending on which buckles I decide to use... or not.🤔
Figure 1. Original Bronco GPW US fuel can and molded-on strap.
Figure 2. The original strap has been surgically removed and replaced with one made from Tamiya tape and threaded through the PE buckle.
Hint: Threading PE buckles: Remove most of the tape's tackiness (not all of it), then smash it even thinner with a metal ruler before attempting to thread those pesky buckles.🔍
HTH🍺
—mike
GulfWarrior
Posted: Friday, June 21, 2019 - 02:29 PM UTC
Thanks everybody! I appreciate all the help!
165thspc
#521
Posted: Saturday, June 22, 2019 - 12:16 AM UTC
Sorry, perhaps I am not adequately "dually demented".
I seem to have a severe problem when it comes to converting sub-inch fractions to decimal milimeters.
GulfWarrior
Posted: Saturday, June 22, 2019 - 12:22 AM UTC
No sweat! I just found a website that would do it!
Isn’t technology grand?!
Owengate
KitMaker: 73 posts
Posted: Thursday, July 04, 2019 - 04:19 AM UTC
Definitely learning a lot from here. Thanks for the tips, fellas!
Posted: Thursday, July 04, 2019 - 04:59 AM UTC
HTH🍺
—mike
Hey Mike-- not to get too picky, but that photo is actually a water can, the fuel can has a screw on top with a chain.
justsendit
Posted: Thursday, July 04, 2019 - 05:54 AM UTC
Hey Russ,
Thank’s for clarifying that typo! ... Uncanny! I was re-shooting the Bronco GPW recently, and realized something seemed off with the “water can” as compared to Asuka’s US “fuel cans” (screw-on type) which I added to another vehicle.
Hmmm... are you clairvoyant?🔮🤔
Now a question: Is that something I should change? It does seem that fuel would be the more logical choice on the aft end.
Cheers!🍺
—mike
Posted: Thursday, July 04, 2019 - 07:36 AM UTC
Mike, I believe that’s the location for the extra fuel can as specified in the manual. But I suppose a crew could put whatever they wanted there.
justsendit
Posted: Thursday, July 04, 2019 - 08:15 AM UTC
Or Bronco Models; their manual has a water can. Lol!
GulfWarrior
Posted: Thursday, July 04, 2019 - 02:04 PM UTC
So, now that I know how wide to cut my tape what would be a realistic color for it. I'm leaning toward Tamiya XF-49 Khaki with maybe a little NATO Green dry-brushed on it.
Incidentally, I got one of those Infini Easy-Cutting Type A mats. It makes getting those straps the right width sooooooo much easier!
Posted: Friday, July 05, 2019 - 03:52 AM UTC
Richard,
I'd say XF-49 is an OK choice. In reality, these straps, exposed to the elements as they were, could fade and change color just like any fabric, so a wide variety of color rangs could be possible, from brand new to worn out. If my own experience with tie down straps is good for anything, I've even seen Nylon straps fade out to various shades of "green". On fuel cans, these canvass straps also tend to get oily or dirty easily. The Physical interaction between fuel and the sun fades them out rapidly. So I'd say khaki is as good as any other color.
GulfWarrior
Posted: Friday, July 05, 2019 - 04:28 AM UTC
Thanks Russ!
18Bravo
KitMaker: 7,219 posts
Posted: Friday, July 05, 2019 - 03:00 PM UTC
This is what you want:
https://store.abovegroundartsupplies.com/products/chartpak-graphic-tape-1-32--x-648--black-matte-16081.html
I've been using it in various sizes for well over thirty years. Saves a lot of time.
Removed by original poster on 07/06/19 - 15:48:44 (GMT).
GulfWarrior
Posted: Saturday, July 06, 2019 - 03:49 AM UTC
Actually, this is what I went with: http://store.spruebrothers.com/product_p/infit3001v1.htm
