Do not cement!
phil2015
KitMaker: 502 posts
Posted: Tuesday, August 18, 2020 - 03:15 PM UTC
Occasionally I come across this instruction for a part that is going to move freely inside another part and I can usually manage to figure out a way to cement the containing parts allowing the inner part to move freely. Working on a Bronco Valentine and they have this set up to allow the gun in the turret to move. The contact surfaces for the surrounding parts are tiny. Any suggestions for what to do in this circumstance?
I may just punt on it and have the gun at a fixed elevation, but I'd like to figure out how to make it work....
Rhode Island, United States
KitMaker: 2,886 posts
Posted: Tuesday, August 18, 2020 - 11:16 PM UTC
I never hesitate to glue down supposedly moveable parts since the idea is that I don't want anyone touching the finished product, let alone playing with it. Just my $0.02...
Dioramartin
New South Wales, Australia
KitMaker: 1,476 posts
Posted: Wednesday, August 19, 2020 - 01:54 AM UTC
Mark has a point, how much do you need the gun to be moveable? If you really do, without seeing the actual parts the following may not be practicable but hereís some ideas: 1) use white glue to bond the ďcontainingĒ elements together and when dry (or rather while drying) gently wiggle the moving part to keep it moving freely. 2) if itís not going to be visible inside the turret, beef up the containing elements with extra pieces of plastic which can be bonded together with styrene glue without it reaching the moving element. 3) Iíve never tried this (so maybe experiment with something from the spares box) but maybe itís possible to coat the moving element with ? Vaseline ? silicone? barrier cream?! which would prevent any glue seepage getting to it
